Thomas Volz Web site
Date:  6-15-2005
Brief Description:  Chain Drive Oil Bath
Oil Bath for Chain Drive: Two holes needed to be drilled and prepped for seals that will hold the oil in the bath once the drive assemblies are installed, also the top edge of the bath has a rubber seal that needs to be installed see image 2. Homer is preparing the adhesive A/B mix showing off his trick of mixing in the bottom of a Mountain Dew can, who would of thought!
Oil Bath Cut out holes and preped lip for seal
Builders assitance Homer Bell mixing sealer
Tape around the side before installing seal
